""This one only gets up to 20mph....turn off the petcock...wait a little (with throttle pinned) then it speeds up to 28mph...then turn the petcock back on before it starves...and it stays at 28mph..""
That was sorta like what I am getting. I though at first the engine was not getting ENOUGH fuel, because my tank was low and it's a gravity feed on these things...but then I realized it had been getting too MUCH fuel - by, as you said, turning off the fuelcock, and within a few seconds I could really fly! In fact, this is the only time I can twist full throttle without it "bogging" down.
Of course eventually you creat a vacuum and the engine is starved of fuel
so I would turn the fuel cock on for a few seconds and repeat the process.
I was actually content with this for a few days - experimenting with just the right "sweet spot" on the fuelcock. This works great for 5-10 minutes, but eventually it either starves for fuel (you turn the cock fully ON and it runs), or it would bogdown with a possible flooding condition (turn the cock OFF and after a few seconds, it takes off again!)
But today, it was getting worse, flooding more and more, and for the first time, I noticed gas pouring out the air intake when the bike is off. That's a definite over-fill of the carb bowl.
So I found this thread, amonst many, looking for "flooding" threads - there aren't any specific ones I could find. But I found one saying to cheack the float and perhaps 'adjust' it by bending the tines...
Well, lol...I took the bowl off and my plastic donut ring float is about half filled with gas.
I found reference to this on one or two other threads. Like the other threads - I can see no leak, so I assume t only let the gas in when it was hot, and slowly over the past weeks. (I have about 35 hours on the bike).
So that is defeintely what's causing the |"bogging down", and I discovered it like Gear Head said, by shutting the fuelcock off while running.
Now the problem is how do I fix this float. I am considering drilling a tiny hole (or two) to get the gas out, and encasulating the whole piece in gas-OK sealant. But the guy that was doing this a few days ago hasn't updated!
I know I can order a new float, even way up here in the frozen north, but I am even considering making one from cork (fisherman's bouy)...hmm
It`s very weird how the gas won`t leak back out!
bMf
KEY WORDS flooding, flooded, float filled with gas, carb float, donut ring
