nightcruiser
DO you have any problems with the chain/sprocket at higher speeds, or is it just when you are moving slow?
I once had a jerky slow ride on my bike, had the original cheap chain, changed to a quality #41 chain, that didn't fix the rough ride. It did stop my chain problems, but slow riding was still jerky.
You had commented about having a hard time maintaining idle on this motor, once again I will say, if your motor is not running smooth then your ride will be rough! When my motor ran like crap at low RPM my ride was all kinds of jerky, at higher speeds the motor ran smoother and jerkyness went away. Think about it, your motor sprocket is chained directly to your wheel sprocket, if the motor sprocket is spinning rough (not turning at a smooth steady speed) then it is gonna jerk on your wheel and make your ride jerky. Once I got my motor running right at low RPM all the jerking stopped for me, if your bike sounds like it is snapping and poping until it reaches a higher RPM (then it smooths out) your ride is gonna be rough.
