Just to add to the "My Bike Doesn't Run" threads...
Farthom
Well, it "kinda" runs. Problems arose just as it ran out of gas one time. I'm not sure if this is actually correlated with the problems but I figured it was worth mentioning. The bike was running, then it ran out of gas. After filling up the tank and trying to restart the problems began. I can only describe its behavior as "excessively boggy" to the point where it will not idle. If I get going quick enough and open up to about 1/2 throttle, it will run, and be able to take me along, however it has next to no power, and it will putz out if you slow down.
Here are the things I have tried thus far:
1) I figured the carb jet might have been clogged. It was pretty caked up with grime I figured it was worth cleaning up anyways. I took it completely apart, and cleaned it up. It looks like new, inside and out. Sadly, it made no difference.
2) I figured the spark plug could have been fouled. I replaced it with another plug to no avail. I even tried a BRAND NEW one, and it made no difference.
3) Perhaps the Spark Plug boot was making a poor connection? I replaced the boot with a brand new one. Still no difference.
4) I unscrewed the little screw on the side of the carb that the gas flows in through, to make sure gas was actually flowing. Maybe my fuel filter was clogged or something along those lines? No, fuel flowed through it just fine.
5) Popped the magneto cover off, and there was a tad of oil inside there, but nothing seemed out of the ordinary.
I notice the engine seems to get much hotter than it usually does if you force it to run this way. Not sure if that is related? (Probably is)
I don't think a head gasket could have blown, I retorqued the headbolts only one day prior to this. However since I am officially out of ideas, i'm willing to pop them off tomorrow and take a look inside.
So to all you experts on here, what would you try next? I find it odd my engine after running flawlessly for a full year and 2000 km would just die on the spot......
Thanks in advance!
Matt
If there's oil in the magneto cover then you've found a problem. There is a crankshaft seal behind the rotor (magnet) If that seal leaks you'll see oil inside the mag cover and you have a major air leak into the engine which will seriously effect the way it runs.
Replacement seals are available from several of the vendors who advertise here. The magneto side is the thin seal, the clutch side is the thicker one.
You'll need to remove the magnet to replace the seal. Do some research, there's lots of information here on removing the magnet and replacing seals. Good luck.
Wouldn't an air leak cause the engine to behave in a "fuel starvation" way, as in high reving, and high heat? I do have the high heat symptom, but the way the engine feels, (boggy) really seems to indicate an over-fuel scenario. I don't think there is an air leak anyways, there was one tiny drop of some fluid that happened to be black behind the magneto cover, but the hole the wires come through is open to the air, and it did rain the other day. I think it was just a drop of water.
How likely would it be that a clogged muffler would cause this?
I'm leaning towards trying to move the carb C-clip one notch up (to lean it out) but given the heat situation I'm hesitant to do so.
Will try popping the head cap off when it cools down a bit. That's like, the one place I haven't looked for a problem.
I notice the carb kind of leaks a little bit around the seal. (Between the bowl and the top assembly with the jet) I wonder if the mechanism that controls fuel intake into the bowl might be broken?
2door, I'm not trying to completely discount your suggestion. I'd just like to hold off on the more drastic fixes for the moment. I'll keep what you said in mind though!
Any ideas on the additional information, especially the leaky carb.
If a picture is worth 1000 words, here's 7000 words to describe my situation. I have taken off the engine head, and taken pictures of the guts. I also took some pictures of the magneto and spark plug.
Please take a look at the magneto images and let me know if you still think there's a leak there.
Without further delay, here are some images.
Piston head in up position.
Piston head in down position. I see an injury here, is this cause for alarm?
Same thing from the other side. A similar injury on this side too.
Magneto
My crappy attempt to show below the magneto.
Seems there's a 5 image per reply limit. 2 more images in my next post.
Piston head cover. Nothing strange here.
The spark plug. Is this a good color for a healthy fuel mixture, or is this getting fouled? Note this spark plug was brand new yesterday and has been run no more than 5 mins. I notice its more brown on one side than the other.....
Let me know what you guys think of these. I'm still pointing fingers at the exhaust pipe or carb. Perhaps I can take some pictures of the carb also tomorrow.
Thanks again!
That scratch in the cylinder wall doesn't look good. There are several causes of that type of damage. Either a broken piston ring, a piece of garbage that was left in from the factory or something that was injested by the engine.
A scar in the wall can cause a loss of compression which isn't a good thing on a single cylinder engine.
From the photo it doesn't appear that you have an appreciable amount of oil in the magneto cover. I'd probably rule out a crankshaft seal at this time. I'm more concerned with the cylinder wall damage.
I took the liberty of enhancing that one photo so others might have a chance to comment on it.
Did you find/see anything that might have caused that scratch?
Totally unrelated to your problem but I'd suggest you eliminate that small spring from your clutch cable. I know the kit instructions say to install it but it actually serves no purpose other than to increase your clutch lever pull at the handlebar. The larger spring is a heat shield; keep it. The small one should go in the trash.
Well I hope I don't have a broken piston ring... I rolled the bike along a little bit without the carb on, and it feels good for compression. It sounds OK, and puts up about the same amount of resistance it did before. I'm no expert, but I'd like think this damage isn't the direct cause of the current problems. I guess it depends on how much of a difference damage like this can make..... What I do like about this theory however is that it supports the sudden appearance of the problems.
I do find it odd that similar damage occurs on opposite sides.... Makes me wonder if a piston ring might have hopped up at an angle or something scraping opposing sides.... Perhaps if this did happen the added friction (metal on metal) could be the cause of the extra heat I am seeing. I was able to easily move the piston with my finger however, and it felt smooth. I'm not so sure.
Sounds like it may be time to take the whole engine apart.
You already have the head off. Just lift the cylinder. It might be stuck to the base gasket but there's nothing else holding it. This will give you access to the piston and rings to inspect them.
Pistons, rings and cylinders are available from most engine suppliers if you need replacements.
The rings will have to be compressed again to reinstall the cylinder, Careful here. Be sure to align the ring gaps with the alignment pins in the ring grooves before reassembly. The base and head gaskets might be salvagable but new ones are advisable.
Good luck.
Before I pop that off, do I need any special tools to reinstall the piston? Something like.... a ring compressor? I don't have any special tools. I don't want to pop it off unless I know I will be able to get it back on.
How do you actually separate the piston from the crank... I have the little retainers on either side of the piston pin out, but the piston pin itself seems wedged pretty good.
You have to heat the rod/piston in an oven so the rod end will "grow" enough to let the pin slide out freely.
Heat it up in an oven...NOT with a torch.
I was hoping to get it off without taking apart the crank case....... I get the sense putting the entire bottom section in the oven would be a bad plan XD
My wrist pins always slide right out with putting anything in an oven.
I might be that you ate the top end bearings.
Heed this advice. The wrist pin should just slide out without heating or pounding on it. The tolerences aren't that close; or shouldn't be.
Well that thing is seriously stuck on there. All my might and I could not move that pin!!! I can push it so that its flush with the side of the piston, but will not slide any further than that. How should I proceed?
