centrifugal clutch remove?
jemsolly
Hi Guys,
Does anyone know how to pull a centrifugal clutch out?
I have taken off the cover and the retaining nut...
Any help would be much appreciated.
Thanks
Joe
How did you get it out? I want to pull mine out to check the one-way spring.
You should have gotten a clutch-pulling tool with your kit.
You remove the bolt holding the centrifugal clutch to the crankshaft, and then the tool threads into the CF and the end of the tool pushes against the crankshaft, and the cf pops right off.
Clutch pulling tool looks like this:
with a cen clutch you still can pedal to start the bike
or do you need a pull starter
I would like to try one of those because on my beach cruiser when I have to pedal fast across a street its really hard to let the clutch go with my hand because the angle of it
where it may be better to just gas it and pedal at the same time
are they pretty much bolt on, or are there other parts needed to intall
yes you can buy the unit and add it.I did about 2 months ago.You can buy them from a lot of vendors.I know you also can search this forum and it will tell you how to install them.
