Is that a three piece wide pedal crankset I see?
yep had to put it on because of the pull start and centrifugal clutch
Is unscrewing itself one of the kinks? I've got the same bike, same motor. I think I may have the wide crank installed wrong. There weren't any instructions with it, tried to find some on the net and came up empty. searched on here and came up with nada. Is the pull start breaking every third time you pull it another one of the kinks?
just built it working out the kinks still
I like how the shadow in the photo makes it look like you have 20 cables coming from the handlebar. : )
Hammond, do you have the 2010 Grubee Pull Start? It is upgraded, steel instead of plastic. You might be able to find a replacement if you have an older engine.
Yes, 2010 Grubee with cable pull start and CF clutch. Love the clutch but the pull start is absolute junk. I don't even try to use it anymore. I've never pulled it three times without it coming apart. Right now I'm busy building an OCC chopper but when I get it done I'm going to try and make something usefull out of the pull start. I'd sure like to find some instructions for the three piece wide crank kit. I have photobucket now so I'm going to try and post some pics of the pieces and see if someone can tell me how to put them together right. I have it put on but it keeps unscrewing itself.
