A long time ago I bought one of the Harbor Freight 79cc 4 stroke engines one sale, got a great deal. Due to work around the house, the engine has sat in the box for months. Now, my time is freeing up, and I am planning my build. After long thought, I think I know what I am going to build.
Here is my plan. I am going to build a custom "longtail" utility bike, similar to this one:
by using pretty much the same technique shown on this person's website:
Long-Tail Cargo Bike
Also, I am going to modify the seatstays and the area directly behind the seatpost to add an engine mount for my 2.5hp Harbor Freight engine. The goal would be to make enough space to leave the HF engine as it comes out of the box (leave gas tank/air filter/etc on). I think to keep things simple, the engine will drive the rear wheel on the left side, and the bicycle crankset will drive the rear wheel on the derailleur side. So the drive will be like a minibike on the left side, using a centrifugal clutch.
I solicit help from you guys because you have experience. I plan on a 26" wheels. I will use the engine mainly to keep my speed up between 20 and 30mph.
Questions-
Sorry for such a long list of questions,
Thanks, Ed
Questions-
- What is the best/cheapest source for a 5/8" clutch for this HF 79cc engine? Northern Tool has this one, is it appropriate? Hilliard Extreme-Duty Centrifugal Clutch — 5/8in. Bore, 12 Tooth, 35 Chain Size | Brakes, Clutches, + Hubs | Northern Tool + Equipment
- What is the easiest clutch to adjust for idle rpm? The Hilliards have different spring kits to adjust the clutch; maybe all these types of clutches are similar?
- What is the approx. idle speed for the Harbor Freight 79cc engine?
- Will a size 35 chain be appropriate?
- Should I plan on using a jackshaft?
Thanks, Ed
