Engine mounting help
Rnalecz
On every manual i read it shows to mount the engine to a t-shaped mount or welding brackets. Cant i just mount the engine to the v-frame using the mounts made on the engine, 80cc engine btw
Howdy RnalecZ
I mounted mine direct to the frame using the engine mouts supplied, but I also placed a peice of inner tyre tube around the frame, this was to surpress vibration and ensure a more secure clamping grip to the frame, these other alternative mounting methods are usually to assist for over size frame styles, if you use the t shaped mount it will make your engine sit higher in the v frame, and this could cause other issue with fitment, see how you go, Im sure other memebers will leave posts for you
Cheers
What bike are you going to mount the motor to?
