EZM Q Matic
cigron
EZM Qmatic transmission
I was told that I should put a few drops of oil on the
Clutch bushing. I would like to know if someone would
Be kind enough to put up a photo .I would not want to
Put it in the wrong place. And mess up perfectly good clutch.
When I learn how to put up photos ill try to be more help
Then I am now. I learned I lot of this site I would like to contribute
To it maybe be of some help to someone.
Put a few drops of 30 weight oil on the 5/8" shaft behind the 10 tooth
sprocket and inside the bearing bracket.
There are a few spacer washers there.
Ride the bike to heat the bushing up so it soaks the oil in.
The MaxTorque clutch has an oilite bushing only on the sprocket side.
See the diagram here
http://www.maxtorque.com/html/ss_clutch.html
attached is a blow-up picture of the Max-Torque six shoe clutch,,,
part #3 is where you need to oil
you want to run the bike for a bit to get the bushing hot enough to weep the oil into it
(make sure the engine is off so the oil doesn't get all over the clutch shoes/bell,,,ask me how I learned that !!!)
