nidyanazo
Craziest thing going on with this HT motor..
Customer said it rode fine for a few miles then shut off.
Brought it back to me and I took a look. At first I pulled the plug and cranked the engine to see if it was sparking.
Was not. I removed the kill switch from the equation, and had now only the blue and black from the engine to the ign box connected.
The white wire was just dangling.
Tried to start it, and it would not fire.
Swapped the plug, ign box, magneto, checked everything over and tried again. It fired up but ran slightly poor... I pulled over with it idling, and looked down. . . The white wire was grounding out on the frame! I could even see the sparks quite clearly. So I removed it and the engine died.
Went to start it again, nope wont start.
I put the white wire back on the frame and presto it starts right up.
What's going on here?
Cliff's: Engine ONLY runs (and poorly) with the white wire fron the engine grounding out on the frame.
What's to make of this?
