RAM motor on scooter without pedals
gstrope
I decided to try something different. I am building a scooter without any pedals. I bought a pull start kit for an 80cc RAM motor and I also will be able to do a bump start. I am mounting the engine higher up to clear the rear frame without using an idler. Here is what it looks like.
That's a really long unsupported fork, attached to a really short, poorly supported head tube. I bet that thing has noteworthy handling issues.
A long head tube with a short fork is much better.
Chalo
Ram? It is a RAW brand...
What size are those wheels?
You are going to have a very low top speed with that stock 44 tooth sprocket.
16" wheel would top out at only 19 MPH at 7300 RPM
Chalo
I used this chassis with a different engine and the forks worked just fine. The only issue I had with is with a front brake they dis shudder a bit.
Sorry, yes it is RAW brand. 20 mph top spedd will be good for this build.
Well, here's what I say: You could cure the brake chatter, uncertain cornering, accelerated headset wear, speed wobble, frame cracking, and all other ill effects of excessive front end flex just by using normal length forks that are supported lower over the wheel.
Cushman did not use long unsupported legs on their forks! That's not an arbitrary design decision on their part; it's the safe and correct way to do it.
Chalo
