Bikeguy Joe
if you want just a little bit louder trimm off the pipe inside the cap and rip out the tin plates channel locks or a small vise grips will do then replace the cap i did this to my riverside/flyinghorse66 youll be verry pleased with the results you may have to run the needle clip one notch richer
This is good info....I have done it on a couple of my builds. Opening up the pipe A LITTLE and making sure the carb is set right are the two cheapest and easiest mods you can do to increase power.
