There is one main reason carb's act like yours.What is going on? My titan carb randomly started leaking fuel out the vent tube, the intake, and flooding the piss outta the engine. Its a brand new carb with like 150 miles on it. I will never find a job if I can't keep this thing running. :|
Take the bowl off and clean the fuel valve needle.
Check to see if the float has gas in it.
Are you using an inline fuel filter?
Tempory fix may be had by rapping the side of the carb to
dislodge any dirt under the rubber tipped valve.
Check your oil for gas contamination.ok float must've been stuck open with a piece of dirt or something
