To all occ chopper owners
Okay this is what i got. I'm putting a jack shaft on it, i already put a ten tooth sprocket on the jack shaft from the shaft to the motor. How man teeth should be on the sprocket next to it. I'm not running the the chain to the free wheel side. I'm just doing it to move the chain over how ever far it has to go to get past the wheel. And i figured i could gear it up from the shaft. Well that's what i got could someone help. Thanks
you asked what speed people got with a 44T. However you did not say what top end that you are looking for? To answer the question you last asked, another 10T would keep your ratio stock.
The drive would be more efficient if you just move the engine over3/4 to 7/8'(no jackshaft losses).
However if you are going to do the jackshaft, seems like multi speed is the way to go.
Single speed and multi speed pics.
Sorry i want to achieve at least 30. The motor mount i made i cant really adjust and I'm so tired of custom making things i just want a simple fix.
Mine with a 44T was winding out around 25 mph. I since switched to a 36Tand I still have climbing torque plus a higher speed.
well, if you want it to work right either b prepared to fork over the dough, or work on that laziness while jammin to the Stones singin' "you cant always get what you want...."
...I personally LOVE the satisfaction from buildin stuff myself!
when i did my occ i got good results with the 10t from motor to a 10t on j shaft and a 12t to a 44t
