Finally it is done with the exception of two 90 degree plowlike pieces in front of the guide and outrigger wheel which will move objects off the track and keep me from derailing. We have 60 miles of abandoned and no longer used railroad at the relatives to use. After checking out various pics and videos on youtube etc I decided that I wanted a conversion that i could ride away short distances and not have a purpose built railbike. The front swingarm swings up and the outrigger is made so that the tubing will slide into each other and can be bungy corded on to my back rack. Except for a few pieces the entire setup is t6061 aluminum with stainless fasteners polished I wanted to keep the weight to a minimum. Figure it weighs about 15 lbs total. I have it all setup for the proper width of the rail and will be taking a testrun here in May. Note the 2 aircraft cable guy wires that keep it all in alignment, tried it down the street and it holds quite rigid.It only takes a 6'' crescent wrench to assemble and adjust. I designed and machined the project through winter so it should be fun if everything works properly!!
