hi guys recently built a bike it runs great but all of a sudden the idle started acting like u had it at half throttle when u first crank it up after you ride a few hundred feet it goes back to normal i cant figure this one out i have idle set good im thinking i might have an air leak around carb somewhere was thinking of running engine and spraying carb cleaner around the carbs area to see if i notice any changes im thinking it could possibly be the cheesy intake manifold tube where the carb slides on as i noticed it can be slid back and forth and while engine runs sliding it back like your going to take it of increases idle but sliding it forward makes idle normal but even when i slide forward and engine cools it does the same thing when started the high idle im thinking of making a gasket for it out of some permatex high temp gasket maker
