deacon
minor bike philosopher
I am continuing to lay out the parameters of the bike I plan to keep from now on. It is of course a rhino drive friction drive bike. I have downgraded from a 48v controller and power supply to a 24v relay system.
At 24volts the bike runs slower of course but it is a great setup as a helper motor. I can pretty much turn it on and just assist it with a pedal now and then. I do have to turn it off going downhill or it will run away. Actually more to save the batteries but so far they haven't been an issue. I don't ride very far at a time.
The frame of the bike is a 26inch mountain bike from the thrift store. I refitted it with a different set of handle bars so that I could ride sitting up comfortably. It has twenty inch wheels front and back so that it is easier for me to mount and dismount. I have the crank set from the 20" donor bike but the chain rings from the 26" bike.
I have no idea what the gearing for the pedals is. I use the largest ring on the three ring front sprocket and the regular coaster rear sprocket. I am pretty sure it is a mountain bike chain that I am using.
The trailer is a center hitched deal. This one is a big ole wire basket set on two 16" bicycle wheels. It is big enough to hold two 17ah plus two 12 ah lead acid batteries, for a total of 29ahs of 24v power.
One thing that makes me nuts on all these custom builds is that no kickstand ever fits them correctly. I always have to cut or weld to make them work.
I have been riding the 24 volts again to check out it's limits since I need some exercise. So far (knock on wood) I have not found a hill I couldn't manage seated comfortably. I did push a little too hard on one or two. I also learned that I didn't need to push so hard. The bike would have done fine, with less help from me. I'm not even sure I needed to help other than the speed fell some. I will have to keep working with it to know just how much help I need to give it.
Anyway that is the setup that I seem to be gravitating to. I might jack it up to 36 volts but I'm not convinced yet.
