Do you have many miles on it? Check the large clutch gear for play, I had the little bearings wear out in mine, it sounds like what I experienced. had to press apart the clutch and replace the bearing, about 45 3mm steel balls.
Hello everyone. So, my newly used bike does this! I have taken the spark plug off and it turns fine. Too much compression. So now what? Thanks for your help!!
