You should keep a fire extinguisher handy with that home made welder!!! (seriously!!)
You should ALWAYS have a extinguisher nearby when doing any welding... period!
You can't argue with logic! It's just a matter of using common sense!
Heh...that's a good rule for any tool that creates sparks. I was using an angle grinder to cut some metal on one of my builds, started feeling something unusually warm around my belt buckle. Looked down and my shirt was on fire...lol.You should keep a fire extinguisher handy with that home made welder!!! (seriously!!)
Thank you,Dude, I am in awe at your ability and creativeness! Really impressive. I am also very interested in your 2 engine build. I have a few questions. What type of engines are you using? If you don't use a clutch, how do intend on sitting idle? How are you going to tie the two motors output together and get them tuned to accelerate together?
Thanks for the tip, it'll be easier for me to ask for some metal. but actually i dont think i need anymore. i have plenty of old bike frames. but thanks anyway. i answered the sync issue in my last post. you can look up there, haha i don't feel like typing it again.J-rell
Congrats on all the heart going into your project.
The metal wholesales/retail sellers also call amounts of metal other than full stock pieces "drops". If you were closer I'd give you all the pipe stock and metal you need.
What's your ideas on sync for the 2 motors? Not like multiple carbs on a single motor that you can sync up. Interesting since I've thought of multiple motor setup myself, but haven't researched the sync issue nor drive setup.
...things that make you go hmmmm.
Have a fun time. We'll be watchin
Alajoyn
Portage MI
hmmmmm i didn't think of that. i would imagine that sounds sweet. i wonder if i could get a a different baffle or something to make it sound more beefy. i think i heard taking out the baffle messes up the cylinder and it kinda disturbs the neighbors. but the engines are the same so it shouldn't be too toughGetting two engines to sync shouldn't be a big issue unless you get one runner and one dog. My dad and I raced go karts back in the 60s and we had several twin engined cars. We ran a separated rear axle. One engine pulled the left wheel the other pulled the right. When they were in sync they made the sweetest sound you can imagine. There was this neat harmonics that would shift from one side to the other, sort of like stereo. Good luck and keep us posted on this build.
You should see the sparks coming from my saw when i cut metal. Sparks fly across my whole garage, i think its beautiful. until a hot piece of metal hits you in the face, thats happened before, not to pleasant. and did you like jump in wter or something? how'd that turn out? one time while i was welding, a chunk of metal burned clean through my jeans and burned my leg. that wasn't to great either haha.Heh...that's a good rule for any tool that creates sparks. I was using an angle grinder to cut some metal on one of my builds, started feeling something unusually warm around my belt buckle. Looked down and my shirt was on fire...lol.
heyyy, well thats my basic idea i just dont exactly know how to make a jackshaft. if you know of any links with pictures please let me know. also! i got pictures! they're kind of blurry but you can get the idea. The chopper looks a little weird because i have a super small wheel on the front and a normal huge one on the back(these aren't the actual ones i'm using). also the fork is placed a little to far up. i got the main parts cut, i just need to weld em all togethor....check em out!Welding up a tube with berrings and zirk grease fittings ect. I know guys on this forum have great setups with jackshafts. I think using a tandem makes it quite easy since 2motors fit easily with outputs on the same side ect.
well i was but i think it looks quite goofy....im gunna get a bigger wheelThat looks like its going to be SwEEt! are you going to keep the scooter front tire on it when finished? that tire is so tiny. might be dangerous in them turns.. just a thought
