Mr. Manta Ray
it just sounds like a good idea for a vertical friction drive no tire wear or blowouts and a lot easier over the precision involved when you put it on the rim which is only a half inch wide
There are numerous problems with this idea. In fact there is more wrong with it than there is right. Unless I am not understanding you correctly. Please answer the following:
How will you mount the motor?
If the motor is a rack mounted vertical shaft how will you get the drive down to the area of the brake disc?
Brake disc's are flexible. How will you overcome this so that the friction roller can grab?
Brake disc's are smooth. How will you overcome this so that the friction roller can grab?
With the disc so small your gearing is now way out of whack and is to high. The bike will have little torque and won't climb any hills. It will be quite fast on the top end however. Once you pedal enough to get the drive to grab. Will this be ok for your use?
I honestly think that you will have the most rewarding experience if you build some sort of rack mount kit. You will likely find the installation challenging and the net result is that you will have a working bike. You will learn much from this endeavor. If you still feel the need to build a motorized bike with your vertical shaft then I would study the videos above and duplicate his plans as closely as possible.
Trying to second guess and re-engineer a design that is already proven to work isn't a good idea. Chances are that the builder in that video has already tried the things you are suggesting and found it didn't work well. I would get in contact with him and find out as much as I could.
If you absolutely positively must build a bike with as little cash input as possible then please consider one of Deacon's weedwhacker (horizontal shaft) friction designs. The motors can be found for next to nothing and often free. It is a much easier build than the vertical shaft design and there are many experienced builders here to offer assistance.
