Adventures in building my bike
Bmetz
1 bought schwinn link mountain bike from wallyworld $169
2 bought grubee 66cc engine kit from place in van nuys ca. $179 delivered
3 found that frame was too small
4 exchanged for womens frame schwinn tube way too big.
5 returned bike and got money back
6 went to dicks sporting gods and bought diamondback full size frame cruiser with front suspension
7 installed motor kit
8 had chain problems and tensioner in kit was junk.
9 broke chain after 20 min slow riding.
10 bought 41 chain and spring tensioner from tractor supply now works.
11 motor twists slightly need to fabricate better mount
12 not too sure abouth the axle ordering HD axle kit and respoking wheels when axle arrrives
13 replaced 50% of the bolts that came with the kit for good American made ones
14 sparkplug wire not good, replaced with modified chevy sparkplug wire:-||
It was the complete kit with the upgraded carb, big tank, spare parts kit. 25 of that wad for fedex.
I prob will have close to $600 after all is done with adding the upgraded hardware.
Don't want to be late for work cause of breakdown and lose my job.
i used masking tape to hold the wires and cables during the build so i didn't waste zip ties and made easier to change things around.
clutch is adjusted, chain tensioner installed, motor mounts fixed, bent the rim when the tensioner came loose and got tangled in the wheel with the chain.
next step, new wheel and hd axle kit.
Here's a sure fire way to keep your chain tensioner from destroying your rear wheel. We have posted this time and time again but guys still continue to install the tensioner with no provisions to keep it from rotating into the spokes. Sorry you had to learn the hard and expensive way.
Dont waste your time with an axle kit. That bike is screaming for a shift kit. replace your wheel however you want, but spend the extra money to get a shift kit from sick bike parts. Your bike is almost not worth riding without it, and that is not a joke.
I am using thread lock between the parts. Thinking about drilling a
small hole to make it more secure now or fabbing something that clamps to both the top and bottom bars.
If you have access to a welder here's an idea. There have been several brackets made that have been clamped instead of welded too. Whatever works for you.
Here's another idea. Get rid of the tensioner completely. It serves no purpose on that particular bike.
