Help! I need a muffler
rearengine
I have a Robin EC04er 40cc 2stoke engine. I would like to put a muffler on like what is on the frame mounted 2stroke engines kits. ( short pipe from the engine then the canester )Do any of you know if they will fit the Robin.. It's a two bolt flang mount. Bolt holes are 38mm center to center. Spooky Tooth said his will NOT fit. I guess I could cut the flang off, and make one. Any info, or Ideas ? Thanks . Bill
I would try a mower shop or the Tractor supply Store, you'll likely find something to fit or at least modify to fit.
Thanks Bikeguy..
I've been to the tractor supply here at home, no luck.. I think what I will do , is by a muffler and go to work on it. little $$, Little cutting, little welding, little time, lots of fun.. thanks Bill
THanks Diceman
I have the problem solved, I went electric...flg.
Your setup is beautiful.
An electric powered recumbent.
About $3,000.00 looks like.
I do homemade recumbent s
some say they are worth at least $2500.00. I dont think so.
Just easyclones.
Not as pretty as yours for sure.
I am cheap I would have spent $6.95 at ace for a muffler.
