deacon
minor bike philosopher
I still don't have all the batteries and won't for a while. They were ordered in three sets because I wanted to test them a piece at a time before I jumped into the build. Hey a hundred bucks is a hundred bucks.
Phase one did come in. Ten aa nimh batteries. I combined them into one 12v cell. It is only 2.5 ah but it does work for a couple of minutes on a 24v motor with a drive wheel attached. So once it worked I ordered enough to make one 12v 12ah battery. It was my plan to co-mingle it with sla batteries and evaluate it. Then someone pointed out that batteries tend to act like water and level out on the surface so I couldn't get a real good feeling that way. That is when I ordered the rest of the batteries.
At this time I have only the one 12v 2.5 cell ready, but I do know how to construct the battery now, so what the heck I can give you that information. I expect you all know how or have better ideas so feel free to share.
Step one.... lay out a piece of duct tape about six or seven inches long. You will get a feel for it.
Step two.....Lay six batteries on the tape but alternate the ends one pos one neg then a pos again. This step is very important
Step three... wrap the tape around and make a packet of it. One long flat battery
Step four.....Get a piece of your wife aluminum foil.Tear of a piece just a little smaller than the width of two battery ends. Remember one pos one neg ends are side by side. You want to connect them.Wrap it over the end of the battery and secure it with a piece of duct tape cut to fit just over the foil but not touching the batteries beside connection.
Step five .....continue repeating step four until you have only one positive and one negative battery end uncovered at each end of the string.
Step Six.......at this point you should have a six volt cell. use your tester and be sure you have continuity at this point. If it reads six volts at this point everything is connected correctly if not try pressing down on the tape connections between batteries to make better connections.
Step seven... Lay the six volt cell aside and begin again. Repeat steps one through six. When you have a second cell tape the two cells together.
Step eight.... At this point use your foil connector to connect the two cells pos to neg on one end ... Your tester should read 12volts when applied to the other ends,.
Step nine....... Attach wires to the ends which have no tape. I use washer with the wires wrapped around the washer and soldiered to hold them... then I duct tape them.
step ten...... I use bands cut from inner tubes to cover each of the tape battery ends to add some spring action to keep the foil connection tight.
Here is where we might part company. I Plan to make 12v cells of 12 ah so I will just make more of these and connect them in parallel. I then connect the 12v cells into series to make my 36v pack. That is because I charge them in 12v increments. i can balance them that way. I suppose you could combine them in series at this point to make 24 or 36v 2.5 ah cells then combine them in parallel with other cells to make your own pack.
The question now isn't whether I can make a 36v 12ah pack it is how it will perform. If you can come up with an easier way I am all ears.
Ps.. A couple of after thoughts. Yes you can get batteries with solder tabs that would be easier.... yes you can get d cells that are 10ah but I chose to go with the very least expensive method. I might have sprung for the others, if I knew in advance how this would perform. So you might want to go one of the other routes after we know how they will perform.
