GreedyRogue
I have a 66cc gt5 that came with a cns v2. Since I couldn't tune that, I bought an nt carb to replace it. I got the rubber o-ring with it to help with air leaks.
Got it mounted and started and the idle was too low. To get the idle anywhere near proper, I had to screw the idle in so far it put a dent in the needle. Contacted the seller, did a few diagnostic tests and was sent a new one free of charge. (Thanks Dax!!!!)
Im having the same issue with the new carb. I even replaced the main jet with a #66 I had to try getting more flow. The screw is in as far as the spring will allow, the slide is up quite a bit, and it still idles so low it actually died when I came to a stop sign yesterday. Here's some pics to show you what I'm talking about.
The first pic is with the screw tightened with the spring still on, not far enough to hit the needle.
I have built 2 other 66cc's with nt carbs and didn't have an issue like this. Any ideas?
