Ernst
After many hundreds of miles my "stinger" on my SBP expansion lost it's end cap...
Bummer but hey it had been riveted and re-riveted but still didn't take the rough roads i run every day to work and back.
So like I do I wandered the local hardware stores and welded a 1/2 inch muffler on to the end where the stinger now removed was.
That lasted about 20 miles before their welds broke and I lost the muffler along the road.
So I had to run for four days as loud as it gets and today was my first day off in 68 straight days of work. So I went to work with 3/4 inch nipple and flexi pipe. Hotwater tank stuff. I assume it's for water?
I start with the benefit of having some weld build up from the first muffler so I start with a thick base.
So, I have taken some pictures and I am limited to three per post so I will make several posts.
Here I start with a standard black pipe 3/4 inch nipple.
I cut this down and bevel for welding. Bevelling allows for a better penetration of the two parts and allows more of the pipe to be welded to the flange.
And here after I have ground the flange which had previous weld build up there is a bit of oil smoke and you can also see better how I bevelled the pipe end.
