Please Notice this thread is to help builders contemplating this type of build, and to offer quick links to other forum members posts of their completed builds.
Whatever style you choose be it a Stretch Cruiser or a Schwinn Stingray OCC Chopper or the XL Chopper ( XL= Adult Sized Chopper ).
Please do as much research as possible before attempting this type of build, read our forum members threads about their builds of this style and type, it'll save you many headaches in the process.
Here's the build list of engine & electrical parts & components with the prices, and the picture of what you might need, you may not need everything on the list for your engine.
Item Id 	Name: 	名称 	Description 	QTY (pcs/set) 	Price(/PC) 	QTY
MC-56-50-04-01 	HEAD LIGHT ASSY 	前照灯总 	  	0  	$35.00
MC-56-50-04-01-01 	BULB 	灯泡 	GB/T15766.1 35/35W 12V   	0  	$7.00
MC-56-50-04-01-02 	BULB 	灯泡 	GB/T15766.1 W5W 12V   	0  	$3.00
MC-56-50-04-01-03 	HEAD LIGHT GROUPWARE 	前照灯组件 	  	0  	$35.00
MC-56-50-04-02 	R.FR.TURNING LIGHT ASSY 	前右转向灯总成 	  	0  	$20.00
MC-56-50-04-02-01 	BULB 	灯泡 	GB/T15766.1 R10W 12V/10W   	0  	$5.00
MC-56-50-04-02-02 	R.FR.TURNING LIGHT GROUPWARE 	前右转向灯组件 	  	0  	$20.00
MC-56-50-04-03 	ALL THREAD HEXAGONAL BOLT 	全螺纹六角螺栓 	GB/T5781 M10*45   	0  	$1.00
MC-56-50-04-04 	PLAIN WASHER 	平垫圈 	GB/T97.1 Φ10*20*2   	0  	$1.00
MC-56-50-04-05 	STANDARD PATTERN HELICAL SPRING LOCKWASHER 	标准型弹簧垫圈 	GB/T93 Φ10*16*3   	0  	$1.00
MC-56-50-04-06 	HEXAGON NUT MODEL 1 	1型六角螺母 	GB/T6170 M10   	0  	$1.00
MC-56-50-04-07 	BRACKET,HEAD LIGHT 	前照灯安装支架 	  	0  	$10.00
MC-56-50-04-08 	HEX FLANGE BOLT INCREASE SERIES 	六角法兰面螺栓加大系列 	GB/T5789 M8*25   	0  	$1.00
MC-56-50-04-09 	HEXAGON NUT MODEL 1 	1型六角螺母 	GB/T6170 M8   	0  	$1.00
MC-56-50-04-10 	L.FR.TURNING LIGHT ASSY 	前左转向灯总成 	  	0  	$20.00
MC-56-50-04-10-01 	BULB 	灯泡 	GB/T15766.1 R10W 12V/10W   	0  	$5.00
MC-56-50-04-10-02 	L.FR.TURNING LIGHT GROUPWARE 	前左转向灯组件 	  	0  	$20.00
MC-56-50-04-11 	WIRING BOX 	电器件盒 	Ⅰ   	0  	$15.00
MC-56-50-04-12 	CROSS RECESS PAN HEAD BOLT 	十字槽盘头螺钉 	GB/T818 M6*12   	0  	$1.00
MC-56-50-04-13 	PILOT LAMP,HEADLIGHT 	大灯指示灯 	  	0  	$10.00
MC-56-50-04-14 	METER ASSY 	仪表总成 	  	0  	$80.00
MC-56-50-04-15 	NATURE DISPLAY LIGHT 	空档指示灯 	  	0  	$10.00
MC-56-50-04-16 	WIRING BOX 	电器件盒 	Ⅱ   	0  	$20.00
MC-56-50-04-17 	HEX FLANGE BOLT INCREASE SERIES 	六角法兰面螺栓加大系列 	GB/T5789 M6*12   	0  	$1.00
MC-56-50-04-18 	STEADY REST,WIRING BOX 	电器件盒固定支架 	  	0  	$10.00
MC-56-50-04-19 	IGNITION SWITCH LOCK 	点火开关锁 	2档4线组合插   	0  	$18.00
MC-56-50-04-20 	FAUCET LOCK 	龙头锁 	  	0  	$15.00
MC-56-50-04-21 	RELAY 	继电器 	LY   	0  	$25.00
MC-56-50-04-22 	RECTIFIER 	调压整流器 	4线组合插  	0  	$20.00
MC-56-50-04-23 	C.D.I.IGNITER 	C.D.I.点火器 	  	0  	$20.00
MC-56-50-04-24 	HORN 	喇叭 	12V/1.5A 105db   	0  	$15.00
MC-56-50-04-25 	IGNITION LOOP ASSY 	点火线圈总成 	  	0  	$25.00
MC-56-50-04-26 	SINGING SPARKING RELAY 	闪光器 	  	0  	$18.00
MC-56-50-04-27 	DIODE 	二极管 	YIN XING DE45   	0  	$15.00
MC-56-50-04-28 	RR.BRAKE LIGHT SWITCH 	后制动灯开关 	  	0  	$10.00
MC-56-50-04-29 	COVER,BATTERY BOX 	电瓶盒盖 	  	0  	$15.00
MC-56-50-04-30 	STEADY REST,BATTERY 	电瓶固定支架 	  	0  	$15.00
MC-56-50-04-31 	STORAGE BATTERY 	蓄电池 	XDC 12V/4AH 120*70*90  	0  	$65.00
MC-56-50-04-32 	SPEEDOMETER LINE 	里程线 	930   	0  	$18.00
MC-56-50-04-33 	MAIN CABLE ASSY 	主电缆总成 	  	D17F2  	$60.00
MC-56-50-04-34 	PROTECTOR TUBE 	保险管 	  	0  	$3.00
MC-56-50-04-35 	ANODE WIRE 	正极线 	350   	0  	$4.00
MC-56-50-04-36 	R.RR.TURNING LIGHT ASSY 	后右转向灯总成 	  	0  	$20.00
MC-56-50-04-36-01 	R.RR.TURNING LIGHT GROUPWARE 	后右转向灯组件 	  	0  	$20.00
MC-56-50-04-36-02 	BULB 	灯泡 	GB/T15766.1 R10W 12V/10W   	0  	$5.00
MC-56-50-04-37 	TAIL LIGHT ASSY 	后尾灯总成 	  	0  	$25.00
MC-56-50-04-37-01 	TAIL LIGHT GROUPWARE 	后尾灯组件 	  	0  	$25.00
MC-56-50-04-37-02 	BULB 	灯泡 	P21/5W 12V   	0  	$6.00
MC-56-50-04-38 	LICENSE LIGHT ASSY 	牌照灯总成 	  	0  	$20.00
MC-56-50-04-38-01 	LICENSE LIGHT GROUPWARE 	牌照灯组件 	  	0  	$20.00
MC-56-50-04-38-02 	BULB 	灯泡 	GB/T15766.1 R10W 12V/10W   	0  	$3.00
MC-56-50-04-39 	L.RR.TURNING LIGHT ASSY 	后左转向灯总成 	  	0  	$20.00
MC-56-50-04-39-01 	L.RR.TURNING LIGHT GROUPWARE 	后左转向灯组件 	  	0  	$20.00
MC-56-50-04-39-02 	BULB 	灯泡 	GB/T15766.1 R10W 12V/10W   	0  	$5.00
Just match the part number with the picture, yes it's as simple as that see the pic below.
Maybe you'd like to see a picture of the engine components well here it is, I've included the price's for each part, remember you may not need some of these parts for your build, this is meant as a FYI builders source.
Here's the part numbers and price list below, again just match the part number below to the part number in the picture above.
MC-56-50-05-01 	ENGINE ASSY 	发动机总成 	  	0  	$350.00
MC-56-50-05-01-01 	STATOR LOOP 	磁电机线圈 	2极   	0  	$45.00
MC-56-50-05-01-02 	SENSOR,GEAR DISPLAY 	挡显传感器 	  	0  	$10.00
MC-56-50-05-01-03 	HEX FLANGE BOLT INCREASE SERIES 	六角法兰面螺栓加大系列 	GB/T5789 M6*30   	0  	$1.00
MC-56-50-05-01-04 	COVER,CHAIN OF ENGINE 	发动机链盖 	  	0  	$30.00
MC-56-50-05-01-05 	ALL THREAD HEXAGONAL BOLT 	全螺纹六角螺栓 	GB/T5781 M6*8   	0  	$1.00
MC-56-50-05-01-06 	CLIP,FR.SPROCKET 	前链轮卡子 	  	0  	$8.00
MC-56-50-05-01-07 	FR.SPROCKET 	前链轮 	420 13齿   	0  	$15.00
MC-56-50-05-01-08 	STARTER ASSY 	启动电机总成 	  	0  	$45.00
MC-56-50-05-01-09 	HEX FLANGE BOLT INCREASE SERIES 	六角法兰面螺栓加大系列 	GB/T5789 M6   	0  	$2.00
MC-56-50-05-01-10 	SPARK PLUG 	火花塞 	GB/T7825 ATRTC   	0  	$7.00
MC-56-50-05-01-11 	CLUTCH ASSY 	离合器总成 	2片   	0  	$65.00
MC-56-50-05-01-12 	KICK STARTER LEVER ASSY 	启动杆总成 	  	0  	$20.00
MC-56-50-05-01-13 	ALLMETAL HEX FLANGE LOCKING NUT 	全金属六角法兰面锁紧螺母 	  	0  	$1.00
MC-56-50-05-01-14 	HEX FLANGE BOLT INCREASE SERIES 	六角法兰面螺栓加大系列 	GB/T5789 M8*104   	0  	$3.00
MC-56-50-05-01-15 	HEX FLANGE BOLT INCREASE SERIES 	六角法兰面螺栓加大系列 	GB/T5789 M6*22   	0  	$1.00
MC-56-50-05-01-16 	INTAKE ASSY 	进气管总成 	  	0  	$18.00
MC-56-50-05-01-17 	HEX FLANGE BOLT INCREASE SERIES 	六角法兰面螺栓加大系列 	GB/T5789 M6*25   	0  	$1.00
MC-56-50-05-01-18 	INSULATOR 	隔热板 	  	0  	$10.00
MC-56-50-05-01-19 	ENGINE GROUPWARE 	发动机组件 	50CC.国际档,手动离合,4个前进档   	0  	$350.00
MC-56-50-05-01-20 	GAUGE,OIL SEAL 	机油 	  	0  	$10.00
MC-56-50-05-02 	MUFFLER ASSY 	消声器总成 	  	0  	$85.00
MC-56-50-05-02-01 	HEXAGON NUT MODEL 1 	1型六角螺母 	GB/T6170 M6   	0  	$3.00
MC-56-50-05-02-02 	GASKET WASHER USED FOR MUFFLER 	排气垫 	GB/T3452.1 Φ24*32*5   	0  	$10.00
MC-56-50-05-02-03 	MUFFLER GORUPWARE 	消声器组件 	  	0  	$85.00
MC-56-50-05-02-04 	ALLMETAL HEX FLANGE LOCKING NUT 	全金属六角法兰面锁紧螺母 	GB/T6187.1 M8   	0  	$1.00
MC-56-50-05-03 	ONE WAY VALVE ASSY 	单向阀总成 	  	0  	$25.00
MC-56-50-05-03-01 	HEX FLANGE BOLT INCREASE SERIES 	六角法兰面螺栓加大系列 	GB/T5789 M6*12   	0  	$1.00
MC-56-50-05-03-02 	ONE-WAY VALVE GROUPWARE 	单向阀组件 	  	0  	$20.00
MC-56-50-05-03-03 	SPRINGINESS LATHE DOG 	弹性卡箍 	KG Φ17   	0  	$1.00
MC-56-50-05-03-04 	BREATHE TUBE 	通气管 	Φ15*41   	0  	$6.00
MC-56-50-05-03-05 	SPRINGINESS LATHE DOG 	弹性卡箍 	CB/T679 Φ15   	0  	$1.00
MC-56-50-05-03-06 	AIR FILTER 	空气过滤器 	  	0  	$10.00
MC-56-50-05-04 	CARBURETOR ASSY 	化油器总成 	PZ19  	0  	$45.00
MC-56-50-05-05 	ANCHOR EAR 	抱箍 	Φ40   	0  	$4.00
MC-56-50-05-06-01 	SYPHON, AIR CLEANER 	空滤器弯管 	Ⅰ  	0  	$8.00
MC-56-50-05-06-02 	SYPHON, AIR CLEANER 	空滤器弯管 	Ⅱ   	0  	$6.00
MC-56-50-05-06-03 	AIR CLEANER GROUPWARE 	空滤器组件 	  	0  	$20.00
MC-56-50-05-06-04 	AIR CLEANER SPONGE 	空滤器海绵 	  	0  	$15.00
MC-56-50-05-07 	CROSS RECESS PAN HEAD BOLT 	十字槽盘头螺钉 	GB/T818 M6*12   	0  	$1.00
Note: You can also shop around for the part you need and look for a better price, now that you know what to look for!
If you have found a source for any of these parts please post it in BarelyAWakes thread http://motorbicycling.com/showthread.php?t=19630
Peace Crazy Horse.
P.S. If you haven't figured it out here's the Roketa website Link below contact them for the parts listed above:
ROKETA,atv, exercise & fitness,dune buggies,scooter,gokart,dirtbike,moped,utility vehicle,motorcycle,electric&gas scooter,water craft,golf cart,bike,quad,offroad,motorsport,jet, sand rails, moped, snowmobiles,helmet,accessories,generator,porcelain do
I always try to suggest if you want a complete package, that is a engine that has all the above components ready for installation on your build, and you want to save some $$$ just search around for a kid's 50cc-110cc ATV you can find them new with prices starting around $399.00 here in the USA
