Norman
LORD VADER Moderator
I'm going to take the stock spark plug boot apart and show you boys and girls just how easy it is to take it apart and put it back together again. Almost everyone hates this thing but if you know what to look for and how it is made and is taken apart correctly you just might change your mind.
The biggest drawback I see is you have to buy spark plugs that have the removable tip so you can use it with this spark plug boot. So I'm going out in the shop with the camera and my white board and bore the $hit out of all of you.
Something to do if your plug wire will not stay in the boot or cdi is to cut off about 1/4" of the wire's end and then reinstall it screwing it, I mean turning it to the right to install
Norman
Norman
