Clutch Pully Mod
Riding Rich
Yes you have seen this before by a man named LARGE Phill......
This is a little diff but the idea came from his thread.
This works very nice and even fits with the billet intake.
If you tighten up the clutch spring youll prolly want to do this.
A couple pics of my custom disk hub mounted sprocket setup.
What is all that white stuff? And it looks like the cable is riding on the cheek of that sheave,here's what I came up with, it works pretty good , thanks rockvoice Later Bob
It is indeed very nice.
Much cleaner than my quick setup.
I made that in about an hour.
The funny thing is i saw this done along time ago and didn't think it made that much of a difference.
It dose.
The pully setup is great no matter how you do it.
Lets you utilize the clutch the way you should to slip it a little and take off.
I'm pretty sure justin has ordered the pully's needed.
I will fab up the brackets and let you know when there ready.
I have alot of projects going on right now.
Pretty much both.
With it you can tighten up the clutch spring inside the motor.
It routes the cable a bit better and keeps your cable from fraying.
The stock position of the barrel for the clutch cable seems to be off enough to chew up the cable and make it hard to pull and eventually break.
It's a nice smoothe pull with the pully.
Sweet I will buy it for sure! I will most likely buy one of everything else on the site. Great products.
That's great you guys! You can buy all kinds of pulleys {like we use on our MBs} at Home Depot starting at $2.00- $8.00, but you still have to modify a bracket to go on clutch cover. So, If $10.00 smackers includes pulley, bracket, bolts, and shipping- it's worth it.dance1
Pretty much both.
Thanks for the response. I think I'll try it, or look for one once they're in production.
