keysertomasi
Hello all,
A bit of a problem. I received my Grubee SkyHawk 48cc 2 stroke kit today and planned to mount it on my 2007 KHS Urban Xpress. As it turned out, the down tube was too big (even though when I measured it, it was within the tolerances), and would need to use some of the extra mounting hardware to make it work.
In order to make the motor fit, I had to figure out how much space the spark plug, and the wire connector (ignition coil assembly) would take up within the frame
. When I tried to connect it.... I couldn't get it to mate. After some trying,I decided to measure the spark plug connector and the spark plug itself. The spark plug: 1/4", the connector 3/16". This seems wrong to me. I think that the connector and spark plug should mate correctly. Has anyone encountered this? Is there supposed to be this sort of size discrepancy?
Also, I'm not sure I will be able to get this motor to fit at all. I can't find anyone who has mounted this type of engine on an '07 Urban Xpress. Anyone? Anyone? Bueller?
Please let me know your thoughts, and thanks in advance!
http://motorbicycling.com/images/smilies/zpt.gif
. When I tried to connect it.... I couldn't get it to mate. After some trying,I decided to measure the spark plug connector and the spark plug itself. The spark plug: 1/4", the connector 3/16". This seems wrong to me. I think that the connector and spark plug should mate correctly. Has anyone encountered this? Is there supposed to be this sort of size discrepancy?Also, I'm not sure I will be able to get this motor to fit at all. I can't find anyone who has mounted this type of engine on an '07 Urban Xpress. Anyone? Anyone? Bueller?
