Ramrider77
Hello: I have noticed when working, boring out my transfer ports! The piston skirt port openings are
alot smaller, than the Transfer ports when lined up ,ATC I was going to open them up carfully to
match the cylinder transfer ports.?Was wondering if anyone has done this also? Plus cut a little
of so the intake is not blocked at all!! it does not open quite all the way! Once i get done with all,
the stuff im doing this thing should really be smooth!! the bearing are getting replaced with new,
& lined up so they dont bind at all!! they were both bound up qiute a bit!
Thank you Kindly!!!
R.R.
Thank you Kindly!!!
R.R.
