You are right, i meant to include this link to another one of "Hillbillys" builds, but he does mention the "Thor" bike. He goes on to say "the motor in the 'Thor' is from an Australian Victa. they used variations of this motor from the 50's through to the early 70's, I like the cast carby and simple lines of this motor. It took a lot of work to to fit it to the bike, I cut down the crank and re threaded the crank ends, removed the magneto/flywheel and trimmed down the crank case to make the motor narrower. I put a crank triggered electronic ignition unit on it, which is hidden in the alloy crank case cover that I also made."Looks like he has the ignition module housed in a faux magneto housing. Looks like 2 wires coming off the bottom of it in the left side pic . Maybe he has a battery hidden in the faux crankcase?
It looks like some aluminum mount bits there between the crankcase and the BB
Here is the link if anyone is interested: http://ratrodbikes.com/forum/viewtopic.php?f=6&t=14042&st=0&sk=t&sd=a&start=30
You metioned the wires coming out of the faux cover, they appear to go to a lever hand control, is that a kill switch? I was wondering if it was an advance/retard lever but he says he has electronic ignition.
I cant see any extra engine mounts between the crankcase and BB.
