Thanks mapbike, couldn't of done it without this site and help from members like you. It was fun and rewarding. Not sure if you noticed the front mount or not. I was a little if'y on the concept but its very solid and holding up great so far.
The only glitch I came across is that I should of bent the muffler just a bit more before I tried cranking down the bolts. It's not completely seated tightly on the gasket. When I tried to tighten it up I think I stripped out one of the studs. For now, leaving it alone. It sounds fine and the only draw back is a bit of oil sputter. Anyway, I wipe down the engine and frame after every ride before I put it away.
Here is one more picture:
