Brakes! How are yours?
azbill
3,358
64
Fountain Hills, Arizona
it looks like bluesky is your better deal, they should bolt right up to your forks
(IMHO, the 180's are overkill :))
any front disc wheel will work...as long as it is not a 'centerlock'...it needs the 6 hole iso standard mount
the bb7's are a good piece of equipment, that is a good price with your choice of rotors as well
(I like the clean sweeps:))
mech disc are easy to maintain, and bb7's have a really good rep
I had a pair of them on my haro full suspension that I sold to finance my mb
just my personal opinion/experience :)
Dave31
11,199
47
Aztlán, Arizona
Thanks Bill, I was reading the reviews of the bb7 and it seems thats the one to go with. Hopefully I can find a cheap used disc wheel.
wheelbender6
4,059
221
TX
VeniceBoy and a few others have mounted disks to a springer fork. Search on his posts. Chainganglowrider.com has a kit to mount a disk caliper to a fork that isn't equiped for it. (I may have not spelled that URL right, but you can google that string and find him).
My brake choice is a coaster with a drum on the front. Drums are retro, quiet, all weather, and can be mounted to anything.
Rambler
48
U.S.A.
Quick question: are there any inexpensive extra wide side pull caliper brakes that will fit around the fenders of my Windwood, or am I SOL? I may go with an HD axle kit with the drum brakes at a later time, but for the interim i would like to have some decent stopping power on the front wheel to supplement the coaster brakes.
Dave31
11,199
47
Aztlán, Arizona
On mine all I had to do was squeeze the fender in a little so the brakes would clear. But no, I do not know of any extra wide caliper brakes. Maybe someone else might have an ideal.
SUNNYLAND SLIM
50
sunnyland
Wild eyed rebel biker... fat marlin brando on a ten speed with a tiny little engine. ^5. That has got to be one of the silliest images I have had in a month. Thanks for the laugh guys.
Opps was supposed to be in helmets again. Sorry
thats funny stuff no matter who you are...
the_edge150
Dealer
Aug 21, 2008
289
Monrovia,CA
the best brake setup i have used for these bikes is my current, a disc brake in the front, and a band brake in the back. i can lock them both up f nescessary
CHIPS X
30
South Central Minneapolis
I have the hub on, brake is functioning. Next step is to set up my light from the dynamo. Someday, pictures will be up, I need to resize them but have no program to do so.
Chips
Newbie
41
Which caliper brakes will work?
With a schwinn del mar, with the fenders left on? I would get a drum brake wheel, but they are just too expensive for me as of now. Any help would be appreciated.
jug98
14
Maryland
Re: Which caliper brakes will work?
I just bought this type from Ebay Black Bicycle Mx Brake - Front Alloy - eBay (item 250506901200 end time Oct-30-09 17:42:46 PDT) and they worked on my DelMar. I leave the fenders off. These had a good radious on them and cleared the fender. If you buy a different type, you can always snip a notch in the fender, on both sides, and just bend it in under the fender, to allow the brake to work. I also have the double brake lever mounted on the throttle side and the coaster brakes removed.
robbdaman
44
SLO
The brakes work great! It really stops fast especially when you use all three, front brake, rear brake, and coaster brake. What an improvement!
Tomorrow I will test them going down hill, did a few today but tomorrow I will go up Sentinel Peak to see how well they really work.
FR31MB/Short Ride - Photobucket - Video and Image Hosting
I really like how this looks and if it works as great as you say I should be doing the same with my ride. I'd have to get some help if I need to do some welding though.
Dave31
11,199
47
Aztlán, Arizona
That set-up worked great, I was reaching speeds close 48 mph going down Mount Lemon and the brakes worked great. I used cheap brakes striped from cheap Walmart bikes. If you were to use more high quality brakes I am sure it would be even better.
I was lucky enough that my Della Cruz already had the mounting holes for the brakes. At the worst you may have to drill new mounting holes.
YouTube - Motorized Bicycle up Mount Lemmon in Tucson,AZ
Mount Lemmon Ride pictures by FR31MB - Photobucket
Comrade Alfonzo
143
Whidbey Island, WA
Anyone thought of adding another set of side pull brakes on the other side of the tube where my Cantiliever brakes are mounted on the rear and then doing a double lever for just the rear's, I hate front brakes bad experience.
