thegnu
I was wondering do any of you know off hand how much power a friction driven bottle generator / dynamo can put out ? I dont have one on hand to test it myself , now heres why .
I was reading some old threads here an was struck by a simple idea that with some minor mods a bottle dyno could be modified to run off of the crank shaft output on the righthand side of the motor, they are cheap an readily available , its almost like the biggest problem thats been in my face with my bike an many others is the amount of available power for running lights , ect. may actually have the simplest an most affordable cure , so if one of you guys could help me out a bit here with this question , an pros an cons I will move forward with this idea.
Thanks ,Gary
ok did some diggin most are 6 volt 3 watts even found 1 thats 12 volt but no info on watts now the question is how many amps or mili amps?
Thanks ,Gary
I'm working on one now using a 6volt 3 watt bike generator. I haven't fired up the motor yet, but here is how it was done (assuming it'll work):
