Will these forks fit?
ElMicNip
Hello,
I was just wondering if anyone out there can assist me. I want to know if these Suzuki Forks will fit my bike. These forks have I believe the same measurements as my fork.
Suzuki Dimensions:
Offset: unknown
Overall Length: 26"
Distance from Bottom Triple Tree to Axle is 16"
Top Triple Tree to Axle is 24"
Length of Neck: 6.5" (probably threadless)
Distance between forks: 4.5"
Axle Mounting Holes: Approx. .39" for a 3/8" Bolt
My Springer:
Offset: ~2.5"
Overall Length: 24"
Distance from Bottom Triple Tree to Axle is: 16"
Top Spring to Axle is: 24"
Length of Neck: 6.5" (threaded)
Distance between forks: 4"; will 2x0.25" spacers work to make 4.5"?
Axle Mounting Holes: 3/8"
I am aware this fork will add weight, but a good triple-tree suspension fork for a bike is soooo expensive. I am also considering saving for a Morini Franko motor an I think fork will do well. Furthermore, what kind of headset will I need or what king of mods will be required. Or is this even possible.
The one big measurement you left out, what's the diameter of the steer tube? Won't work if it won't fit in the head tube.
Well yes that measurement would help, huh. I can't believe I forgot to post, well mine is 1" (threaded) and the suzuki fork states 1" fork stem (it looks threadless). Here is another pic I found, but with a cool 6v headlight.
