Wheel Sunringle MTX33 26" rim 13ga Sapim spokes 20mm thru axle hub
Built on a sealed bearing 20mm through axle hub that has disc brake interface on both sides. The hub is off brand, I used a countersink to create the taper the spoke heads seat in like higher end hubs have. The hub can accommodate 2 disc rotors.
Front disc brake wheel
Sunringle MTX33 26" rim, the info I could find lists tire size from 1.75"-2.5" for this rim
Sapim 13 gauge Stainless Steel custom spokes purchased from YoJimbo bike shop.
This was for a build I was planning that never happened. The plan was for a 3 speed dirt jumper style build, possibly an ebike.
I recently started unloading all my bike stuff.
Will post link for listing on ebay below.
If the link doesn't work go to ebay and search
And it will come up.
If you click on my seller icon you can see the rest of the bike stuff I have listed on ebay
I'm in Clearwater Florida if someone wants to pick it up locally
Wheel Sunringle MTX33 26" rim 13ga Sapim spokes 20mm thru axle hub | eBay
Sunringle MTX33 26" rim, the info I could find lists tire size from 1.75"-2.5" for this rim. Built on a sealed bearing 20mm through axle hub that has disc brake interface on both sides. The hub can accommodate 2 disc rotors.
www.ebay.com
