Waspswatter
Sounds like it's coming from the clutch when I ride. Is that normal? Lol, it sounds awful! Does it need some grease?
AND, My clutch lever keeps riding up out of the clutch. The pin that's supposed to hold it in isn't doing anything. When there's no tension on the clutch cable you can pull the lever right out of the clutch. What can I do about that?
BTW, initially I had trouble getting it to start, but I then went through the archives, (I USED SEARCH AND IT WORKED!) thought it might be electical and put a zip-tie around the connectors to pinch them tight against the downtube. Started right up!
