Transferport
max350
An easy way to control the flow into the transfer portarna.du need a propane torch or similar
Caution! do not heat the cylinder too much
http://youtu.be/VlmFEMXYZYY
what exactly are you doing in that video? the only thing I can really see is SEEING where the transfer is aiming, but I dont see any actual modification/control... If this is a simple way to correct transfer angles, then for sure I'd be interested in this.
This a rather crude method to see how the gas flow occurs in the cylinder, what you see is the gas mixture hits the rear cylinder wall. if the angle is wrong in the transfer port gas mixture might end up in the wrong place, such as in the middle of the cylinder instead of the rear wall
