midwestmayhem
So I've been thinking about this for a while, and since I finally pulled the 66cc apart to true up the crank, I'm wondering about it even more.
Piston covers up a fair bit of the transfers at bdc. One can mod the piston crown; But if the crown is cut far enough down to completely open the transfers, you'll probably run into the piston ring.
Cylinder can be raised to open up the transfers, but this reduces the compresson height and the compression. Top of cylinder can be decked to gain some compression back, but the compression height is still less than stock so overall compression will still be less.
Hears my idea..
So what if one was mod the piston crown a reasonable amount. Then figure out (measure) the stroke needed to fully open the transfers and keep the compression height and squish band the same as stock. Crank would be stroked to that, cylinder would then be shimmed up the amount the stroke was increased by. In the end one would have a motor that wouldn't sacrifice compression for transfer flow. I did a little math and a stroke somewhere around 43mm should be just about right. (stock is 40mm)
66cc crank's have been stroked using puch cylinder, build's not done yet though. http://motorbicycling.com/showthread.php?t=40181&page=2
Any thoughts on this?
Hears my idea..
