I think you meant to type "spokes".
Have you verified that you can fit the sprocket flush to the hub? Disk-break hubs are usually too wide to permit sprocket-mating. That said, I HAVE in the past attached a standard sprocket to a 32-spoke wheel with a disk-brake interface. I had to use a Dremel to increase the size of the sprocket-hole, and then cut out notches to match the disk-brake bolt nubs. This resulted with the sprocket fitting in such a way that power is transmitted directly to the hub and not the spokes in the rag-joint. Since 32 is not equally divisible by 9, I was only able to adequately secure 4 bolts, but this was enough to secure the sprocket successfully.
That said, I HIGHY recommend that you invest in a disk-brake/sprocket adapter. All told, I spent about $75 on mine, and wish I'd don it years ago. It's painful laying out that much for a seemingly simple device, but it's saved me untold hours of anguish.
This is the one I have, and it's given me ZERO issues. It's also convenient since I can quickly swap it to my WINTER wheel (this week). No more fiddling with rubber-rags, and torquing bits and pieces of bolts, washers, and nuts.
http://www.bicycledesigner.com/rotor-and-sprocket-adapter.html
The sprocket is SUPURB. It's aluminum, but it's tough. I have many hundreds of mile on it, and it's shown NO signs of wear.
