Tachometer
Wevil Kenevil
441
420
Sack a tomatoes California
I'm not sure if this is against policy to post stuff like this but I have found tachometers on wish.com for $3 that they're selling on bikeberry for 39 in case anybody's looking for one. I'm not sure what the shipping is but I know it's a lot cheaper than $39. Just a heads up looking out whatever.
Sidewinder Jerry
2,054
1,049
Rockwood, TN
Wow it's the cheapo one at that.
  • Like
Reactions: Wevil Kenevil
Mossy
1,128
819
I adjust the timing by ear with an offset key or a star washer... About 1mm of retardation is a good place to start on the china doll... 1mm advance on the 4 stroke 79cc... The gearing and load will determine the sweet spot... Also the cruzing rpm be careful to hold everything in position when tightening up so it doesn't move on you...
  • Like
Mossy
1,128
819
The strength of the magnet the wraps on the coil the CDI the plug wire the plug gap the heat range of the plug are going to have enough difference to make every build a little different... Move it a little bit at a time until you notice a difference.. bad better good excellent ok not so bad worse and back to excellent knowing the parameters... And the carb will need a little adjustment... Same way knowing the RPM and exact timing in degrees is nice to know for reference but it doesn't really matter with these engines because there all going to be a little different...
  • Like
Mossy
1,128
819
With a fixed timing situation... No advance it's not like most engines... There was a Jaguar/Suzuki CDI years ago but the inventor was banned that had advance... He's on Facebook with most everyone else... The forums have only hurt the motorized bicycle development in my opinion... Now that the bad actors are long gone it's never recovered
  • Like
Wevil Kenevil
441
420
It never ceases to amaze me the amount of knowledge that has been amassed by all of my friends here and other places.
You are a knowledge of Fountain bro and I greatly appreciate you thank you so much for taking the time to reply to this post you're all awesome!
