Stock Sprocket, drill holes for use with Manic Mechanic Adaptor?
MysterySandwich
Well... pretty much as the title says -- is it possible to take a stock sprocket and drill some holes or do whatever so it could fit on a MM adaptor?
I've done it.
Measure it real good, so you get it centered good, so it will not wobble/hop.
I'll try to get a picture of it tonight.
it's possible. just make sure you get the holes centered properly. i drilled and countersunk a steel, 30t moped sprocket to fit one.
i also modified a MM sprocket to fit a moped hub that's got 6 mounting holes cast into it.
i had to bore out the center hole of the sprocket and use some forgotten high school geometry to center all the holes but it works fine.
