kingislnd32
Hi, new guy here.
I am currently using the stock carb on my 80cc bike engine kit. When i go at a steady speed at around 20 MPH at 1/2 throttle or so the engine starts four-stroking. It accelerates fine but once i start going a steady speed it starts happening. It will happen at wot too. I have the needle set at its leanest setting. I have checked that the choke doesn't accidentally come on and there are no air leaks.
The one way i have found to fix it is to put the fuel on/off valve halfway on. My guess is that i need to adjust the float in the carb. I feel like i have read that 21 mm is the best float level.
My question is what is that measurement?
How to i measure that?
If that isnt the correct level what is?
Anything else i should try to fix this.
p.s. my spark plug is a good color
Thanks,
Isaac
Thanks,
Isaac
