Degoragon
I have a Skyhawk GT5 66CC engine. Recently, the clutch jammed after a wheel bearing broke apart, and sent my back wheel into the frame. It jams in a particular place, so I believe the clutch arm may be bent.  Of course, I cannot remove the clutch to inspect the arm and replace it. I have all the nuts removed. I have tried to use the clutch puller, to no avail. I have already broke one puller, and with the other one, the wrench just slips off. Any way to remove a clutch that will not pull out with the standard puller and wrenches?
