mrfubs
hello folks,
Im selling my bicycle build i lost my interest.
if you are interested please click the links below.
http://motorbicycling.com/picture.php?albumid=1360&pictureid=8074
VIDEO
http://www.youtube.com/watch?v=1_kAkipr1jM
It is a Kent La Jolla cruiser with a highly modded engine.
Custom fabbed a yz80 expansion chamber on it.
*CRANKSHAFT:
DAX lower end with upgraded crank bearings and the best crankshaft you can have in one of these engines, the connecting rod has copper trush washers 3 oil holes on each end of con rod and quality needle bearings.
- Drilled additional out of crank for higher RPM
- Crank is stuffed to maximize crankcase pressure.
*ARROW's Reed valve
*3rd transferport for more efficient fuel delivery into cylinder.
*Front suspension fork to absorb bumps with a 203mm hydraulic disc brake.
*Yamaha PW80 16mm carburetor jetted for 1-2000ft above sea level.
* 36T sprocket for speed
* PUCH HI COMP CYL HEAD
This bike runs Extremely well for what it is, Tap the throttle and the RPMs are right there it responds just like a dirtbike.
The engine produces a tremendous amount of torque in the low rpm and once you hit the power band you can go up any hill with ease with a MAX speed of 47 mph at 8700 rpm.
I am from MICHIGAN.
VIDEO
*CRANKSHAFT:
*ARROW's Reed valve
I am from MICHIGAN.
