Saving the coaster brake
DDbike
I am new to this. I am building my first build using an onex as my frame.
I have heated up the coaster brake and bent it so it will work without rubbing; however, the sprocket does not allow for the coaster brake to seat itself securely and tends to scrape on the center hole of the sprocket.
Is there a way to extend the brake seat outward by using washers or something so that my coaster does not interfere with my sprocket?
...never mind ... I figured it out. I dropped the jag joint and went with a MM adapter and 40 tooth sprocket
