First, I lost the pin that holds the choke lever in, I finally got around to messing with it today. As it turns out, a spoke is the right diameter to shove in the hole, problem solved?
Not quite, now my slide doesn't go high enough to disengage the choke lever, so now I have no problem engaging the lever, the problem is disengaging it, lol.
It's warming up, so I probably don't need it as much, but does anyone have any idea? Other than removing the arm that latches and just move the lever manually.
I thought about trimming the spring on the slide, so it reaches the top and disengages the choke, but I don't know it that will prevent the slide from returning fully.
