robert todd
I just built my first motor bike . Two issues i used a heavy workman rear wheel it looks like it is getting more and more play in the rear axle. I did tighten the big nut that holds the coaster brake lever. no help. Do I need to pull the whole wheel to tighten it up? The other issue when pulling in clutch, clutch does not disconnect fully. Clutch cable is tight seems it takes alot to push clutch lever in.More force than clutch handle can give. I am guessing it is not good to let it sit still and idle. Even when bike sits still I can smell clutch getting hot , slipping. Is it best not to sit still with motor running? THANKS
