Warphones
Hello family and friends! I have been trying to obtain 50mph on my pk80 and am getting closer with every mod. Right now I'm hitting 41mph(gps) and know it will go faster.
I have also read that the dellorto clones you can drill out the top hole of the jet tube to allow more high rpm fuel delivery. And also modify the slide. I am reluctant to get a mikuni carb or anything else as I've read the dellorto should be able to get to 50mph. Maybe......
Does anyone have advice or has anyone reached 50mph on similar setups? What did you do to get to 50mph?View attachment 104024 View attachment 104025 View attachment 104026 View attachment 104027
- Pk80
- High compression head
- Copper head gasket
- Ported/matched intake/exhaust
- Ported/matched knifed transfers
- SKS bearings crank/clutch
- G2 Reed w/19mm intake
- Dellorto SHA/HP 15.15 with .68 jet
- Windowed/ramped piston
- Fatbelly expansion chamber (cheesy but cheap, temporary till mz Miami restocks the mz65 pipes)
- 36 Tooth Sprocket
- NGK B6HS Plug
- Stock CDI
- Stock timing
- Stock magneto
- .6 gallon tank
- 20:1 fuel
- Spring chain tensioner with sprocket roller
- Custom tank mounts
