Quick Question!
Flyman
What is a good all round rear sprocket size for a 28 inch wheel, on a china girl powered bike.
I,m , 250 lb.
Fly.shft.
Hmmm.......
I'm no expert on gearing.
But the stock sprocket is 44 tooth. I think I'd recommend going a bit larger.
You're not monstrously heavy. But 250 is something to consider. Plus your wheel is going to have a larger diameter than most.
I know there's a 48 tooth available. I think there's a 52 tooth. I'd go with one of those.
With a 52 your bike might not be fast. I think you can count on that.
I tend to advise slow, slow speeds. So you gotta take my advice with a grain of salt.
But, that said, I'd go with the 52.
Well the big wheel I know changes the ratio, but I thought maybe someone has run a 28 rear wheel.Ya my weight is going to factor for sure.
Fly
Imagine a 26" bike with a 44 tooth sprocket. A 250 lb rider is not going to overpower that engine. That's not a problem.
Your larger wheel, of course, will change your gear ratio. To the tune of 28 divided by 26. Or 14/13. You can see that it's not a huge difference. You'll gain speed and lose torque by that ratio. A 48 tooth sprocket will counter-act this by the ratio 48/44 or 12/11. With a 48 tooth sprocket your gearing will be as near as no matter to a 26 in with a 44 tooth.
Now, are those spokes 14 gauge? I'd be concerned about that. A 28 inch wheel with 14s might be just a bit delicate for this application.
If that's the case, then I'd really recommend low speeds. Then a 52 tooth, or even larger, might be the right one.
Hi there ... I just thought , for what it's worth , I would throw my 2 cents worth at ya ...
This past season I built a couple of '29ers' and it was my experience that on the 29" wheel the 44 tooth sprocket was pretty much compairable too about a 36 - 38 tooth on a 26" wheel ... SO ..I would think that if you want too have about a 'stock kit' gearing ... I would guess a 50ish tooth sprocket should put you fairly close . If you want a bit more top end rather than low end torque I would suggest a 48 tooth .. while on the other hand , if you prefer the low end torque and aren't trying ta set any speed records , the 52 tooth would the choice
Sounds like a road bike wheel set ... I think that alot of them run the 28" wheel ..?? although I have to admit ... I have had 'zero' experience with any road bikes at all ... I don't think they would stand up well too the demands a motor puts on the bike ... But hey .. I've been wrong b-4 ... lol
At any rate ... ENJOY yourself with your project .. because really , when it's all said and done , that IS what most of us do this for !
Is that the bike your asking about ? the link too E-Bay ? I went to it and found a hot looking red bike .. that it ?
well be sure ta post the results .... that bike should work just fine from what I see it'll make a real nice ride for you.
