I got a tail/brake light with three wires. Green is ground, brown is tail, yellow is brake. I want the brake light to come on when squeezing either brake lever (will be purchasing a set of levers with brake light switches). I don't want to always have to squeeze a certain lever to activate the brake light, as there may be times where squeezing one lever or the other may not be desirable or necessary, and I may either forget or pull the lever out of habit, and it could end badly in either case (taking a spill for pulling the wrong lever or getting rear ended for forgetting). So my question is, how can I make either lever activate the light? I am buying a 6 position wire terminal block, I'm just not sure how to do it. Do I need a tail light harness?
